16 years agoFFT output?
This is probably going to be a simple question, but have been unable to find documentation to explain it. I'm running a 512 point 24 bit width data streaming FFT. My output is 24 bits with 6 bits o...
16 years ago --- Quote Start --- The altera documentation states it uses block floating point for the FFT. so what your saying is, and if my data is x"DEADBE" with an exponent "011100" (28 or -4) than it would shift my value down by 4? and my signal would be x"DEADB.E" sorry im a little confused, not sure if that makes sense. --- Quote End --- It might actually be floating point then, just with an 6 bit exponent and 17 bit mantissa instead of the standard 8/23. This reduces logic requirements on the chip. It basically sacrifices range and accuracy so that it uses less resources (and possibly clock faster too).
