15 years agoFFT output scaling
I will be grateful if anyone can help me here, because I'm having a really hard time trying to sort things out. I've already made a VHDL test bench to simulate a transform of a sinusoidal signa...
15 years ago --- Quote Start --- since 9 zero LSBs, then 15:0 and one sign bit make 26 bits while full range is 27 bits then sign bit repeated. --- Quote End --- So I must repeat the sign bit as many times as needed to match the full range width? For example, assume I would like to left shift by 5, so I do: full_range_real_out [26:21] <= {real_in[15],real_in[15],real_in[15],real_in[15],real_in[15],real_in[15]}; full_range_real_out [20:0] <= {real_in [15:0],5'b0};
