11 years agoFFT megawizard stimulation
Hi ! I am new to megacore I generated the FFT core in vhdl. But I couldnt to run the stimulation in modelsim. I attached the tb_fft.vhd fft.vhd and fft.vho file to the project in modelsim.Shoul...
10 years agoif you specify what the errors, I can help you.
Do you use the megawizard plug-in fft? The code is generated by magwizard. I just modified it for my inputs. --- Quote Start --- hi feradiskaras , i am also working on FFT , but my code gives so many errors, can you just share your code, i am working on my FYP. thanks..help will be appreciated.. --- Quote End ---
