8 years agoFFT megacore (variable-stream) sink_ready deasserts after dynamic size change 16->32
Hi, it is me again. In my previous thread on the FFT IP (https://www.alteraforum.com/forum/showthread.php?t=57800&p=235198) core I posted this: --- Quote Start --- I attempted to f...
8 years agoOkay, I was able to fix this problem after carefully timing events as the size changes. SOP should pulse on the same cycle as fftpts_in is changed, and on the next cycle, I de-asserted sink_valid to prevent loading of more data into FFT while the FFT is outputting results of previous size. While this is happening, sink_ready is de-asserted by the core. This can now reassert when the pipeline is empty.
