12 years agoFFT MegaCore simulation
Hi, I'm working with Altera streaming 1024 points FFT core (fft v13). I want to get spectrum but i'm enable to extract frequency information from outputs. Anybody can help me please! Thank...
12 years agoYou're not very clear on what you're doing. My guess is you're using DSP Builder and the FFT Megacore as that screenshot looks like a Simulink scope. If you want useful answers you need to give much more information so that people don't have to guess.
You've connected your input data and output data to a scope, which always shows a signal plotted against time. To get a graph of the frequency you need to save that data to a variable using a "To Workspace" block. Then you can use the MATLAB command "plot" the points against any values you like. You may be able to do it directly using the vector scope block as well.
