12 years agoFFT MegaCore Function Output is not as expected
Hi, I have generated one FFT MegaCore Function in my FPGA design and simulated it using test bench. And the output is compared with the expected values; but they are not same. the parameter...
12 years agoyour data vector in above post is not 1024 samples but 1159 samples and it lacks continuity at wrap-up.
you must enter a known 1024 frame in both your fft and your reference model. your power equation should not include sqrt unles you use 20*log... regarding scaling by exp you can find out that from your fft doc or once you get correct signal you can find out the right scaling.
