12 years agoFFT MegaCore Function Output is not as expected
Hi, I have generated one FFT MegaCore Function in my FPGA design and simulated it using test bench. And the output is compared with the expected values; but they are not same. the parameter...
12 years agoThe input samples (15 bits wide) in integer are:
21577,18450,14977,11706,9150,7709,7613,8871,11289,14486,17963,21173,23610,24891,24820,23404,20867,17606,14132,10993,8680,7556,7798,9369,12021,15338,18799,21860,24041,25003,24592,22870,20114,16750,13308,10329,8282,7488,8069,9935,12796,16197,19610,22496,24401,25031,24281,22275,19322,15888,12513,9725,7963,7503,8416,10562,13601,17059,20389,23070,24683,24973,23896,21620,18501,15031,11752,9181,7722,7601,8840,11243,14433,17910,21127,23581,24882,24832,23436,20914,17660,14184,11036,8708,7564,7785,9336,11973,15284,18748,21820,24018,24999,24608,22906,20163,16804,13359,10370,8306,7490,8049,9898,12745,16144,19561,22457,24381,25031,24303,22314,19373,15942,12560,9760,7981,7500,8394,10521,13550,17005,20341,23036,24667,24978,23922,21663,18553,15083,11799,9214,7735,7594,8813,11201,14382,17858,21083,23549,24872,24843,23468,20959,17712,14237,11079,8735,7571,7772,9303,11927,15230,18695,21778,23992,24994,24623,22942,20210,16858,13410,10411,8329,7494,8032,9862,12696,16090,19510,22419,24360,25031,24324,22351,19423,15996,12610,9797,7999,7497,8370,10482,13499,16952,20293,23002,24652,24985,23947,21704,18606,15138,11844,9246,7747,7586,8785,11157,14328,17805,21038,23520,24862,24853,23496,21004,17765,14290,11124,8763,7578,7757,9270,11879,15177,18644,21736,23968,24988,24639,22976,20257,16911,13460,10450,8350,7493,8012,9823,12645,16035,19460,22381,24340,25032,24346,22390,19473,16050,12658,9834,8017,7494,8346,10440,13448,16897,20245,22968,24636,24991,23974,21747,18658,15190,11892,9279,7762,7578,8756,11112,14276,17751,20991,23488,24851,24864,23527,21049,17819,14342,11166,8790,7587,7744,9239,11834,15125,18592,21693,23940,24983,24655,23010,20306,16966,13512,10491,8375,7496,7993,9789,12597,15982,19411,22344,24320,25033,24366,22430,19524,16103,12708,9870,8034,7491,8323,10401,13396,16843,20197,22933,24621,24996,23998,21789,18709,15245,11938,9310,7775,7570,8729,11068,14223,17700,20946,23458,24839,24873,23557,21093,17872,14395,11211,8820,7596,7731,9207,11787,15071,18540,21650,23915,24976,24672,23045,20353,17019,13564,10531,8399,7500,7976,9752,12549,15929,19359,22303,24298,25032,24387,22467,19574,16159,12758,9908,8054,7489,8299,10360,13347,16789,20149,22897,24603,24999,24023,21829,18761,15297,11986,9344,7788,7562,8701,11025,14170,17646,20902,23427,24829,24885,23586,21139,17925,14447,11255,8849,7605,7719,9175,11740,15018,18489,21608,23888,24971,24686,23080,20401,17073,13615,10573,8425,7504,7959,9716,12500,15875,19309,22264,24276,25029,24407,22506,19623,16211,12807,9945,8073,7487,8277,10320,13295,16735,20100,22862,24586,25004,24050,21872,18812,15351,12032,9378,7804,7556,8674,10982,14119,17592,20856,23397,24817,24894,23617,21184,17978,14500,11299,8877,7614,7706,9142,11694,14963,18436,21566,23862,24965,24701,23113,20449,17126,13666,10613,8447,7508,7942,9680,12451,15821,19259,22224,24254,25029,24427,22543,19673,16265,12856,9982,8094,7484,8256,10282,13244,16682,20052,22826,24571,25008,24073,21912,18864,15406,12080,9412,7818,7549,8647,10940,14066,17539,20810,23365,24806,24904,23646,21229,18031,14553,11344,8907,7624,7696,9112,11649,14910,18384,21525,23835,24957,24715,23146,20497,17180,13718,10654,8472,7512,7925,9644,12403,15767,19209,22185,24231,25027,24446,22581,19722,16320,12905,10020,8113,7485,8233,10242,13193,16628,20004,22791,24553,25011,24097,21954,18916,15458,12127,9445,7833,7542,8621,10897,14015,17485,20764,23334,24793,24912,23674,21271,18083,14607,11389,8936,7633,7684,9081,11603,14858,18332,21480,23807,24949,24729,23178,20544,17233,13769,10696,8496,7516,7908,9609,12355,15713,19157,22145,24209,25025,24464,22617,19772,16373,12956,10058,8133,7483,8212,10203,13143,16574,19955,22755,24535,25014,24120,21994,18967,15513,12174,9479,7849,7537,8595,10856,13963,17433,20718,23303,24780,24921,23702,21316,18135,14659,11434,8965,7643,7673,9050,11558,14805,18280,21436,23780,24943,24744,23213,20590,17286,13820,10738,8523,7522,7892,9574,12307,15660,19107,22105,24186,25023,24484,22654,19820,16427,13007,10095,8154,7484,8191,10165,13094,16520,19906,22719,24517,25017,24146,22035,19018,15566,12223,9514,7864,7530,8567,10812,13911,17379,20671,23268,24767,24928,23732,21360,18188,14712,11479,8996,7653,7661,9019,11514,14751,18227,21393,23753,24935,24757,23245,20637,17339,13872,10780,8548,7528,7876,9540,12259,15606,19056,22066,24164,25021,24503,22692,19870,16480,13057,10135,8175,7485,8169,10125,13044,16467,19857,22682,24499,25021,24169,22076,19068,15620,12271,9548,7880,7525,8542,10769,13859,17326,20625,23237,24754,24937,23759,21404,18240,14765,11524,9027,7664,7651,8988,11468,14699,18175,21349,23724,24928,24771,23279,20684,17394,13924,10823,8574,7533,7860,9505,12211,15552,19005,22025,24140,25018,24521,22729,19919,16534,13106,10173,8196,7484,8148,10086,12993,16413,19808,22646,24479,25023,24192,22116,19120,15673,12319,9582,7895,7521,8517,10728,13807,17272,20577,23203,24739,24944,23787,21448,18292,14818,11569,9057,7675,7640,8959,11423,14646,18123,21305,23695,24920,24784,23310,20730,17447,13976,10864,8600,7537,7844,9473,12163,15499,18953,21984,24116,25014,24539,22764,19968,16589,13157,10211,8217,7484,8129,10049,12943,16359,19759,22608,24460,25025,24215,22156,19171,15726,12367,9618,7911,7515,8492,10686,13756,17220,20530,23171,24727,24954,23814,21492,18346,14871,11614,9088,7686,7629,8929,11377,14592,18069,21261,23666,24910,24796,23342,20776,17501,14028,10907,8627,7544,7829,9438,12116,15445,18902,21943,24091,25010,24556,22800,20016,16642,13207,10252,8239,7486,8110,10010,12893,16305,19709,22571,24441,25028,24236,22195,19221,15781,12415,9653,7928,7511,8467,10644,13704,17165,20484,23138,24712,24960,23842,21534,18397,14924,11660,9118,7698,7621,8899,11333,14539,18017,21217,23638,24901,24807,23372,20821,17554,14080,10950,8653,7548,7813,9403,12068,15390,18852,21902,24067,25008,24573,22836,20065,16695,13257,10291,8260,7486,8089,9973,12844,16251,19660,22534,24420,25029,24259,22234,19272,15835,12463,9689,7944,7507,8442,10604,13652,17112,20437,23104,24698,24967,23869
