12 years agoFFT MegaCore Function Output is not as expected
Hi, I have generated one FFT MegaCore Function in my FPGA design and simulated it using test bench. And the output is compared with the expected values; but they are not same. the parameter...
12 years agoI am calculating '10*log10()' to convert the linear value to power in 'db'.
Anyhow, can you please tell what the scaling factor I have to use? Is scaling factor '-10' as seen in 'source_exp'?
