12 years agoFFT MegaCore Function Output is not as expected
Hi, I have generated one FFT MegaCore Function in my FPGA design and simulated it using test bench. And the output is compared with the expected values; but they are not same. the parameter...
12 years agoNow I am checking with positive numbers only..
But still the output is not as expected.. Can you please verify my calculations are correct or not//
