12 years agoFFT MegaCore Function Output is not as expected
Hi, I have generated one FFT MegaCore Function in my FPGA design and simulated it using test bench. And the output is compared with the expected values; but they are not same. the parameter...
12 years ago --- Quote Start --- One mistake I feel is that, when we convert the integer values above 32768 to binary, they are becoming negative values since they are using signed representation. Is this the cause of problem? If so, then how can I give 16 bit unsigned input to FFT MegaCore? --- Quote End --- what you interpret as positive above 32767 will be viewed as negative by fft if it is set to 16 bits signed. For a start use positive only below 32767 and see. then for negative numbers convert using the rule that a negative number is same bits as positive if you add 2^16 to it.
