17 years agoFFT Mega Core IP
I am working on FFT MegaCore IP. I would like to give 64 points to the generated file and get the output using Altera DE2 board not the simulation. I built a top level file.v to pass the inputs...
17 years agoNo.
The problem is how to pass inputs and get the outputs using the Altera FPGA board. There is no relation with the PC at all. There are the data: assign inputdata [1] = 15; assign inputdata [2] = 1; assign inputdata [3] = 5; assign inputdata [4] = 10; assign inputdata [5] = 5; assign inputdata [6] = 1; assign inputdata [7] = 6; assign inputdata [8] = 7; assign inputdata [9] = 5; assign inputdata [10] = 11; assign inputdata [11] = 5; assign inputdata [12] = 10; assign inputdata [13] = 5; assign inputdata [14] = 1; assign inputdata [15] = 10; assign inputdata [16] = 5; assign inputdata [17] = 6; assign inputdata [18] = 2; assign inputdata [19] = 3; assign inputdata [20] = 8; assign inputdata [21] = 9; assign inputdata [22] = 1; assign inputdata [23] = 5; assign inputdata [24] = 10; assign inputdata [25] = 5; assign inputdata [26] = 1; assign inputdata [27] = 9; assign inputdata [28] = 8; assign inputdata [29] = 2; assign inputdata [30] = 6; assign inputdata [31] = 5; assign inputdata [32] = 10; assign inputdata [33] = 5; assign inputdata [34] = 8; assign inputdata [35] = 4; assign inputdata [36] = 9; assign inputdata [37] = 2; assign inputdata [38] = 4; assign inputdata [39] = 5; assign inputdata [40] = 9; assign inputdata [41] = 7; assign inputdata [42] = 9; assign inputdata [43] = 5; assign inputdata [44] = 10; assign inputdata [45] = 5; assign inputdata [46] = 1; assign inputdata [47] = 15; assign inputdata [48] = 20; assign inputdata [49] = 5; assign inputdata [50] = 25; assign inputdata [51] = 23; assign inputdata [52] = 10; assign inputdata [53] = 5; assign inputdata [54] = 15; assign inputdata [55] = 15; assign inputdata [56] = 11; assign inputdata [57] = 1; assign inputdata [58] = 7; assign inputdata [59] = 17; assign inputdata [60] = 19; assign inputdata [61] = 5; assign inputdata [62] = 1; assign inputdata [63] = 5; assign inputdata [64] = 10; These data are passed to the generated file but there is no output from the FFT generated file.
