11 years agoFFT IP core and QSYS
Could anyone explain me how do I connect FFT IP core in QSYS? I have tried to use SGDMA but the bits/symbol doesn't match. I don't have DSP Builder.
11 years agohi,i also use fft ip and connect it to nios through sgdma. however, i load to the development kit and the result is not correct.
i make a component of fft and connect it to qsys; in creating component, i only add the wrapper(my_fft.v) and fft ip top file(fft512.v) as follow(not add the file of fft lib ), i am not sure it can call the fft lib and synthesize the correct hardware. http://www.alteraforum.com/forum/attachment.php?attachmentid=10816&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=10817&stc=1 http://www.alteraforum.com/forum/attachment.php?attachmentid=10818&stc=1 i load to development kit ,but the result is wrong like this , could you give me some help. Thank you very much. http://www.alteraforum.com/forum/attachment.php?attachmentid=10819&stc=1 my wrraper code:
module my_fft (
clk,
reset_n,
sink_valid,
sink_sop,
sink_eop,
sink_in,
sink_error,
in_empty,
source_ready,
sink_ready,
source_error,
source_sop,
source_eop,
source_valid,
source_out,
out_empty);
input clk;
input reset_n;
input sink_valid;
input sink_sop;
input sink_eop;
input sink_in;
input sink_error;
input in_empty;
input source_ready;
output sink_ready;
output source_error;
output source_sop;
output source_eop;
output source_valid;
output source_out;
output out_empty;
wire sink_real;
wire sink_imag;
wire source_real;
wire source_imag;
wire source_exp;
assign {sink_real,sink_imag} = sink_in;
assign source_out = {source_real,source_imag};
assign out_empty = (source_eop)?2'b0:2'b0;
fft512 fft512_int(
.clk(clk),
.reset_n(reset_n),
.inverse(1'b0), //use fft
.sink_valid(sink_valid),
.sink_sop(sink_sop),
.sink_eop(sink_eop),
.sink_real(sink_real),
.sink_imag(sink_imag),
.sink_error(sink_error),
.source_ready(source_ready),
.sink_ready(sink_ready),
.source_error(source_error),
.source_sop(source_sop),
.source_eop(source_eop),
.source_valid(source_valid),
.source_exp(source_exp), //not used
.source_real(source_real),
.source_imag(source_imag)
endmodule
