17 years agoFFT IP Core 8.1
Hi, I m using FFT IP core for the first time. i have spent several hours and experimented on different size andn types of FFT Functions using startix II. I still cant get EOP right while using wav...
17 years agoI would like to ask you that why you need to do all that? You can only pass the source_real and source_imag to the NIOS.
In your simulation, can you take the NIOS code into your account?? or you only simulate the verilog code. I think you are using the waveform file for simulation purposes.
