17 years agoFFT IP Core 8.1
Hi, I m using FFT IP core for the first time. i have spent several hours and experimented on different size andn types of FFT Functions using startix II. I still cant get EOP right while using wav...
17 years agoThis FFT is really unpredictable. The cntroller which works for me in uni, doesnt work when i use it at home. however i'll attach the controller which works with quartus 7.2 (most of the time though). genrate a symbol file for this controller and assert the sink ready and reset high in BDF file. Use the BDF file to provide inputs and monitor outputs. this is a 1024 point FFT controller with 16 bits. It instanciates the megacore genrated FFT named "FFT", so change the name if u use a diff name.
good luck regards Omar Anwar
