17 years agoFFT IP Core 8.1
Hi, I m using FFT IP core for the first time. i have spent several hours and experimented on different size andn types of FFT Functions using startix II. I still cant get EOP right while using wav...
17 years ago --- Quote Start --- Hi, I m using FFT IP core for the first time. i have spent several hours and experimented on different size andn types of FFT Functions using startix II. I still cant get EOP right while using waveform simulation. i.e. in case of 64 points, i have tried a gap of 62,63,64 cycles between sop and eop but still i m getting source error 3(When EOP is asserted before N valid samples are accepted). There should be a point (far far away from sop) where if i insert EOP, i should get error 2 ("Missing EOP" is asserted if the FFT accepts N valid samples of an FFT frame, but it is not completed with an EOP signal.) but this error never occours. I m using 40ns clock time period and i have tried EOP at the end simulation uptil 20 usec. Still error code 3. FFT user guide suggests that sink ready should be asserted high (which is an output). if i assert this signal high, FFT sets it to low after first SOP and it never gets high again. I am attaching both input and output vwf files. ANY HELP WILL BE HIGHLY APPRICIATED. Regards Omar --- Quote End --- i have similar pro.:confused: Would someone help me?
