17 years agoFFT 8.0, sink_ready de-asserted
Hi, I am trying to test the functionality of FFT version 8.0. The device family that I am using is Cyclone II. Below is the parameter of the FFT: Transform Length: 64 points Data Preci...
17 years ago --- Quote Start --- i understand that, but you should try asserting reset_n for the first few clocks of your simulation. --- Quote End --- Hi, I have with me a new waveform, with some changes in the reset_n. But the FFT block still display the same error (source_error = 11). It seems like it was able to accept data, but not all the N valid samples are accepted due to sink_ready that de-asserted half way through the process.
