17 years agoFatal Error happened during FFT block compilation
I am using Quartus II 8.0 Web Edition. Using MegaWizard Plug-In Manager I had generated fft.vhd file. The vhd file can be compile successfully. However, when I create new project and then create bloc...
17 years ago --- Quote Start --- Hi, It is kind of embarrassing but I had to admit that it was my mistake. I had taken a look at Pletz’s project and his project can be compiled successfully. I am not sure what cause the fatal error but what I am sure is that fft block had to be connected, if ‘all’ the pins are left unconnected, then fatal error will appear. It is my mistake for not connecting the pins of the fft block. But the reason why I did that is because initially when I connect the fft block, I receive the fatal error. So in order to check the error, I compile each block and come to the conclusion that the megafunction blocks are what caused the problem, my other blocks are non megafunction. But now, when I re-do my initial work (connecting fft block with others), there isn’t fatal error anymore and I have no idea why. So, thanks again Pletz, I no longer face the fatal error problem. --- Quote End --- Hi, you shouldn't be so hard to you, such things happens all the time. Hopefully I could help you. Happy new year Kind regards GPK
