17 years agoFatal Error happened during FFT block compilation
I am using Quartus II 8.0 Web Edition. Using MegaWizard Plug-In Manager I had generated fft.vhd file. The vhd file can be compile successfully. However, when I create new project and then create bloc...
17 years ago --- Quote Start --- Hi , you should install at least the service pack for the 8.0 version. If this does not help you should try the 8.1 version of the Quartus Web edition. BTW you don't need a licence anymore for the 8.1 version. In the meantime I will try to reproduce your problem on my PC. What is your FPGA target family? GPK --- Quote End --- Hi, I run a test project with Quartus 8.1. I generated the FFT directly in the toplevel directory and used Verilog as description language. I works fine. Have look into may project. I had to delete the db folder in order to reduce the size of the zip file. Run the compilation again.
