Knug
Contributor
5 years agofalse_path issue seen in the STA tool when running 'check_timing'
I set false path to the following signal :
set_false_path -from [get_ports fpga_nstatus]
& when I run STA check_timing reported 'no input delay was set on the input port'
Same with other false ...
RichardT_altera
5 years agoHi @Knug
Sorry for the late response.
In Check Timing, the no_input_delay check verifies that every input port that is not determined to be a clock has an input delay assignment. Thus the message reported.
You might have wrote a wrong sdc command thus no unconstrained paths reported.
In the Timing Analyzer, you can set false path by clicking Constraints > Set False Path to ensure that the tool recognize the paths.
You may checkout the user guide here on set_false_path sdc command and its example.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-scripting.pdf
Richard Tan
