15 years agoFailure to configure S4GX device using MAXII with PFL
hi. im using the MAXII with PFL ip to configure S4GX device. the flash device is numonyx 256M flash.
i am able to program the flash & load a sof file using the JTAG if to the S4 but when i try usung configuration using the PFL - no success. im using the FPP scheme - burst mode. is there any importance to the option_BITS?? what is it? are there any known issues with the quartus 9.1? is there a ref design for the maxII using PFL? i really need ur help.. thnx3 Replies
you have to use the --optionbits --programmingmode and --pfl flags:
http://www.altera.com/support/kdb/solutions/rd08102010_306.html - Altera_Forum
i also think there were some issues with sof2flash in 9.1, you'll want to use 9.1sp1 or 9.1sp2. you should be able to find a solution that has the details
i have to state that im not usin NIOS..only MAXII with PFL
