Matt_P
2 years agoF-Tile Reference and System PLL Clocks IP
Hello FPGA Forum, I'm working with the IP "F-Tile Reference and System PLL Clocks Intel FPGA" IP and the 'Multi Channel DMA for PCI Express' example design. I'm trying to understand the connection...
VenT_Altera
2 years agoHi @Matt_P,
Thanks for your reply.
For the Refclk source of System PLL in the F-tile Reference and System PLL Clocks IP, the naming of RefClk # is fixed. The user can choose one of the 8 RefClk from RefClk[0] to RefClk[7] as the Refclk source for the System PLL.
You may enable the desired Refclk # for FGT PMA from Refclk#0 to Refclk #9. If you want the Refclk #2 instead of Refclk#3, you may enable the Refclk#2.
VenTing_Intel
