F-Tile Reference and System PLL Clocks IP
Hi @Matt_P,
Thanks for your reply.
For the Refclk source of System PLL in the F-tile Reference and System PLL Clocks IP, the naming of RefClk # is fixed. The user can choose one of the 8 RefClk from RefClk[0] to RefClk[7] as the Refclk source for the System PLL.
You may enable the desired Refclk # for FGT PMA from Refclk#0 to Refclk #9. If you want the Refclk #2 instead of Refclk#3, you may enable the Refclk#2.
VenTing_Intel
Hi @ventt
Is this mean that I can choose any one of refclk source in the F-tile Reference and System PLL Clocks IP, and then enable it for FGT PMA. Since this selection is logical, and I need to assign the input clk of PLL to physical pin in qsf? (Dont care about CDR feature.)
In this case, physical refclk pin is CH3, and I can select RefClk source #2 in IP GUI. Then I assign the refclk pin in qsf to CH3?
- paveetirrasrie_Altera2 years ago
Hi yanghao1,
The thread has been closed. Kindly post a new forum thread to get support from our experts.
Pavee
