15 years agoExternal Avalon MM interface
Hi all, I need to interface a microporcessor external to fpga to a Nios system using a shared memory. So, I thought to use a onchip memory module in dual port configuration which will be accesse...
15 years agoFYI some time down the road I plan on replacing those master templates to be based on the masters from the modular SGDMA design example. To control those from outside of SOPC Builder will require an additional gasket to breakout the control signals. The master templates are a bit old and lack a bunch of features that the mSGDMA supports which is the reasoning behind the switch.
If you want to give the modular SGDMA masters a shot send me a PM and I can give you early access to the bug fixes I just rolled in.
