15 years agoExternal Avalon MM interface
Hi all, I need to interface a microporcessor external to fpga to a Nios system using a shared memory. So, I thought to use a onchip memory module in dual port configuration which will be accesse...
15 years agoHi BD,
Thank you for your answer. Both the solutions you suggested are feasible for my system. The one based on master template is much more complete and ready to integrate in sopc builder; I took a look at the example and documentation and I think I can easily use it. Anyway, I'd prefer something more simple, since I don't need to access the whole Avalon bus but only a small shared memory. Then, the second solution seems to be better for my case, but I'm not very expert in HDL coding and I never used the Component Editor. I think it should be an easy job but I fear I would lose a lot of time in learning all that stuff to extract the minimal information I need. Do you know if an example is available of the interface shown on page 12 of external_processor_if.pdf ? Cris
