15 years agoExternal Avalon MM interface
Hi all, I need to interface a microporcessor external to fpga to a Nios system using a shared memory. So, I thought to use a onchip memory module in dual port configuration which will be accesse...
15 years agoHi Cris,
You can refer to some examples provided at: http://www.altera.com/support/examples/nios2/exm-avalon-mm.html But it seems that it can add to some complexity of your design requirement. If so, you can take a look at options given in: http://www.altera.com/literature/hb/nios2/external_processor_if.pdf Please refer to p11 of above pdf file titled "Custom Bridge Interfaces". I think that it is the simplest method of having external processor accessing an SOPC builder system peripherals. Hope this helps. Cheers, BD
