16 years agoEthernet MAC/PHY (LAN91C111) with Stratix II
Hello everybody, I’m a French student in electronics engineering. I’m trying to use the Ethernet MAC/PHY (LAN91C111 device) IP with Nios II but I have some problems with the pins assignments ...
16 years agoDon't trust Altera's documentation for the pins assignments, it seems to be wrong (it's not the first time, unfortunately).
Have a look at the schematics to find the correct pins instead. From what I'm seeing (I hope I found the correct schematic on the net), those are the correct assignments: [list][*]ENET_DATACS_N: AB24 instead of T20 [*]ENET_IOCHRDY: AB25 instead of V26 [*]ENET_LDEV_N: AA24 instead of T26 [*]ENET_SRDY_N: AA23 instead of T25 [*]ENET_W_R_N: AE27 instead of T21[/list] You should check all the other pins too, you never know what other mistakes they made in their documentation...
