16 years agoError when compiling simple video application
Hello, I try to compile a very simple system using two video Megacore functions and a Nios II -test pattern generator directly connected to - video output during compilation I have got the f...
13 years ago --- Quote Start --- While it may not always be the case, we found the solution to errors such as these are to check the IP Cores that the file uses and install/reinstall using the Megawizard. Has worked nearly every time. --- Quote End --- Hi trennert, I facing the same issue. Can you please mention in detail.
