16 years agoError when compiling simple video application
Hello, I try to compile a very simple system using two video Megacore functions and a Nios II -test pattern generator directly connected to - video output during compilation I have got the f...
15 years agoWhile it may not always be the case, we found the solution to errors such as these are to check the IP Cores that the file uses and install/reinstall using the Megawizard. Has worked nearly every time.
