15 years agoerror when build nios IDE
hi! i am using an example of DE2_media_computer. When i build interrupt_Example_C, I get one error. But i don't know how to dug it. please help me!! thank so much! this error appear...
15 years agoI just solved this problem today. Open the BSP Editor from the Nios II SBT and select the Linker Script tab. You need to add a linker section named ".reset" to the "sdram" linker region (which is in the sdram memory device). That should get you past the error you described.
