Error (10773): Verilog HDL error SystemVerilog extensions
Well, there's a problem.
Error (10773): Verilog HDL error at timer_control.v(5): declaring module ports or function arguments with unpacked array types requires SystemVerilog extensions
This warning came up, so I did System Verilog extensions when I set up the module... Probably.
But this error still pops up. Is there a solution?
<code>
module timer_control(RESET, CLK, SW, DATA);
input RESET, CLK;
input [2:0] SW;
output [7:0] DATA [31:0]; //<-- This is an error code!
integer count;
reg [6:0] min, sec, m_sec;
reg [6:0] rec_min, rec_sec, rec_m_sec;
reg start, lab;
always @ (posedge CLK) begin
if(~RESET) begin
count = 0;
end
else if(start) begin
if(count == 10) begin
count = 0;
m_sec = m_sec + 1;
end
else begin
count = count + 1;
end
if(m_sec == 100) begin
m_sec = 0;
sec = sec + 1;
end
if(sec == 60) begin
sec = 0;
min = min + 1;
end
if(min == 60) begin
min = 0;
end
end
end
always @ (*) begin
if(~RESET) begin
start = 0;
rec_min = 0;
rec_sec = 0;
rec_m_sec = 0;
lab = 0;
end
if(SW[2])
start = 1;
if(SW[1])
start = 0;
if(SW[0]) begin
rec_min = min;
rec_sec = sec;
rec_m_sec = m_sec;
lab = 1;
end
end
binary_to_digit min_control (min, MIN_FRONT, MIN_END);
binary_to_digit sec_control (sec, SEC_FRONT, SEC_END);
binary_to_digit s_sec_control(m_sec, HOUR_FRONT, HOUR_END);
endmodule
- sstrell
You're putting a 2D array on an output instead of an internal RAM (which is what I'm guessing you are trying to implement). Shouldn't this be not in the port list like this:
reg [7:0] DATA [31:0];
Found a super old post that might help as well:
- ak6dn
(1) The output port DATA is never referenced in your module code. So is it really needed?
(2) You can't use multidimensional arrays in ports in verilog. Use DATA[255:0] instead and manually assign bit fields.
(3) Use the <CODE> block feature of this forum. It makes your code MUCH easier to read and understand.
- ShengN_altera
Seems like the issue addressed had been resolved. I'll now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts.
Thank you.
