assn1
4 years agoError (10773): Verilog HDL error SystemVerilog extensions
Well, there's a problem.
Error (10773): Verilog HDL error at timer_control.v(5): declaring module ports or function arguments with unpacked array types requires SystemVerilog extensions
This w...
ak6dn
4 years ago(1) The output port DATA is never referenced in your module code. So is it really needed?
(2) You can't use multidimensional arrays in ports in verilog. Use DATA[255:0] instead and manually assign bit fields.
(3) Use the <CODE> block feature of this forum. It makes your code MUCH easier to read and understand.
