15 years agoError (10147): Verilog HDL error at ColQueue.v(39): identifier "ColQueue" cannot be u
Hi there! I made 3 queues to push pixel data in, with Mega Wizard. It is asynchronous FIFO, and target is MAX II. How is the solution of below issue? plz help! Error (10147)...
15 years agoYou didn't mention in which expression the error is generated. If you are using colqueue for another object than the module name, it would be plausible.
P.S.: I see, you posted the code in the meantime. Can you please clearly indicate the reported error location?
