15 years agoError (10147): Verilog HDL error at ColQueue.v(39): identifier "ColQueue" cannot be u
Hi there! I made 3 queues to push pixel data in, with Mega Wizard. It is asynchronous FIFO, and target is MAX II. How is the solution of below issue? plz help! Error (10147)...
15 years agoThis compilation error does not happen when the module was not used.
But if there are syntax error, even if the module are not used, compilation is failed. So, this problem is not came from syntax error, I think, Rather than the MegaWizard setting. Plz Help! Thx!
