11 years agoenhanced precision troubles in DSP Builder 13.0.1
I am running my first experiments with DSP Builder with Enhanced Precision. My trial etup is to use NIOS, load DSP Builder subsystem with numbers (ultimately to do FFT, etc.), and write back to shar...
11 years agoI hope this is not the problem: DSP Builder book 3 says:
The following features do not work in a system that has an Enhanced Precision Support block, or any subsystems: ■Enabled subsystems ■Bus blocks ■Demux primitive block Does this mean that I cannot use NIOS which has (?) bus blocks (?) along with Enhance Precision. I was hoping to use NIOS to drive the DSP builder subsystem with data, and retrieve results. I'm not sure how to interpret this statement in the Adv DSP Builder book. Hopefully, I can do what I want with NIOS and Enhanced Precision. :)
