10 years agoEndless trouble with HDMI output (Bitec IP core)
Good evening from Japan, I'm having endless trouble getting HDMI output to work on my Arria10 ALARIC (ReflexCES) development board, Bitec HDMI output FMC card and Bitec HDMI IP core. I'm g...
10 years agoIn the end the problem was solved thanks to support from Andy@Bitec. There was a problem with the clock driving the TPG and HDMI core part of the design. I used independent clocks to drive my TPG and HDMI core, but should have used the output clock from the transceiver directly. Doing that it worked right away. Yeiii!!!
