suppamax
2 years agoEMIF on Agilex 5
Hi, I am trying to generate a DDR4 controller for Agilex 5 E-series, but all I seem to get is an empty box. The generated verilog files look like this [max@parma Workarea]$ cat quartus_dummy/d...
suppamax
2 years agoThe generation report says
Info: Generated by version: 24.1 build 115 Info: Starting: Create block symbol file (.bsf) Info: qsys-generate /home/max/Workarea/quartus_dummy/ddr4.ip --block-symbol-file --output-directory=/home/max/Workarea/quartus_dummy/ddr4 --family="Agilex 5" --part=A5ED065BB32AE6SR0 Info: Finished: Create block symbol file (.bsf) Info: Info: Starting: Create HDL design files for synthesis Info: qsys-generate /home/max/Workarea/quartus_dummy/ddr4.ip --synthesis=VERILOG --output-directory=/home/max/Workarea/quartus_dummy/ddr4 --family="Agilex 5" --part=A5ED065BB32AE6SR0 Info: ddr4: "Transforming system: ddr4" Info: ddr4: "Naming system components in system: ddr4" Info: ddr4: "Processing generation queue" Info: ddr4: "Generating: ddr4" Info: ddr4: "Generating: ddr4_emif_ph2_mem_device_ddr4_220_gvofvjq" Info: ddr4: Done "ddr4" with 2 modules, 1 files Info: Finished: Create HDL design files for synthesis Info: Starting: Generate IP Core Documentation Info: No documentation filesets were found for components in ddr4. No files generated. Info: Finished: Generate IP Core Documentation
I am targeting Agilex 5: A5ED065BB32AE6SR0
I have installed the Agilex 5 no cost license (but I have not been able to complete the generation of the programming file of the NIOS-V example I've found, see here)
