HBhat2
Contributor
6 years agoE-Tile Transceiver " Reverse Parallel Loopback"
I want to use " Reverse Parallel Loopback" feature for some protocol analyzer application.
I understood that in L-tile, Reverse serial loopback mode doesn't support for GXT (more than 17.6Gbp...
Deshi_Intel
6 years agoHI HPB,
I consulted Intel internal team but so far we are not aware of any speed limit requirement on Etile reverse loopback path.
However, one important requirement in using reverse loopback path is (0ppm difference between the transmit and receive frequencies).
- You need to take care of ppm difference between your external test equipment and FPGA Etile refclk else data re-transmission from Etile Rx back to Tx path may fail
dlim
HBhat2
Contributor
6 years agoHi @Deshi_Intel ,
Thanks for checking internally & confirming that there is no speed limit for reverse serial loopback in E-tile Transceivers.
Can you provide some more details/document references on "(0ppm difference between the transmit and receive frequencies)"?
With Regards,
HPB
