16 years agoDynamic Reconfiguration and Clock problems
I've tried compiling the altera's reference design for dynamic reconfiguration and it compiles perfectly. In the design there are 4 gxb each with 2 refclock and one reconfig module. However, when I implemented the same thing in my design, quartus says that it can't fit the design since it's only allowed to have 8 global signals into quad. It seems that in the reference design the reconfig_clk pin is left unassigned which quartus then assigns one to it during compilation, but that's not possible in a real design. Anyone got any ideas on how to fix 4gxb with 2 refclock with dynamic reconfiguration into one quad? Thank you in advance2 Replies
So you are actually using both refclk pin pairs into the quad? That is slightly different from my designs. I have several designs that use two reference clocks, all 4 GXB in a quad with TX and RX, and dynamic reconfiguration. However, I also ran into the problem of not having enough global clocks to support all of the clock signals. What I did was use the assignment editor to tell Quartus NOT to put the recovered clock from the receiver on a global route.
e.g.
Jakeset_instance_assignment -name GLOBAL_SIGNAL OFF -to *rx_clkout_wire* - Altera_Forum
Thanks Jake! It works!
