14 years agoDynamic addition/submission in Stratix-V DSP block
Hello all, I want to use the Stratix V DSP block to build a ALU. I need the dynamical addition/submission control like the addnsub sginal in Stratix II. According to what is described ...
14 years agothere is a template in Quartus > Edit > Insert Template > Verilog > Full Designs > Arithmetic > DSP Features > Dynamic Add/Sub
for reference:// Quartus II Verilog Template
// Dynamic add/sub control
// For use with the Stratix V, Arria-V, Cyclone-V and later device families
module dynamic_addsub(a1, b1, a2, b2, a3, b3, a4, b4, a5, b5, a6, b6,
addnsub12, addnsub34, addnsub56, subnadd_chain34, subnadd_chain56,
clock, ena, reset, s);
parameter a_width = 18;
parameter b_width = 18;
parameter o_width = 64;
input a1;
input b1;
input a2;
input b2;
input a3;
input b3;
input a4;
input b4;
input a5;
input b5;
input a6;
input b6;
input addnsub12;
input addnsub34;
input addnsub56;
input subnadd_chain34;
input subnadd_chain56;
input clock;
input ena;
input reset;
output s;
reg signed a1_reg, a2_reg, a3_reg, a4_reg, a5_reg, a6_reg;
reg signed b1_reg, b2_reg, b3_reg, b4_reg, b5_reg, b6_reg;
reg signed s12, s1234, s;
//Dynamic add/sub can be used in basic modes: sum-of-2 18x18, 36+18x18, two level sum-of-4 18x18, sum-of-2 27x27 and sum-of-2 36x18.
//Input and output signals of the dynamic add/sub operation must be explicitly defined.
wire signed p1, p2, p3, p4, p5, p6;
wire signed p12, p34, p56;
assign p1 = a1_reg*b1_reg;
assign p2 = a2_reg*b2_reg;
assign p3 = a3_reg*b3_reg;
assign p4 = a4_reg*b4_reg;
assign p5 = a5_reg*b5_reg;
assign p6 = a6_reg*b6_reg;
assign p12 = addnsub12 ? (p1 + p2) : (p1 - p2);
assign p34 = addnsub34 ? (p3 + p4) : (p3 - p4);
assign p56 = addnsub56 ? (p5 + p6) : (p5 - p6);
//Dynamic add/sub is also applicable to chainout adder or accumulator (not both).
//Dynamic add/sub is not applicable to 18x18 systolic mode.
always @(posedge clock or posedge reset)
if (reset) begin
a1_reg <= 0;
a2_reg <= 0;
a3_reg <= 0;
a4_reg <= 0;
a5_reg <= 0;
a6_reg <= 0;
b1_reg <= 0;
b2_reg <= 0;
b3_reg <= 0;
b4_reg <= 0;
b5_reg <= 0;
b6_reg <= 0;
s12 <= 0;
s1234 <= 0;
s <= 0;
end else begin
if (ena) begin
a1_reg <= a1;
a2_reg <= a2;
a3_reg <= a3;
a4_reg <= a4;
a5_reg <= a5;
a6_reg <= a6;
b1_reg <= b1;
b2_reg <= b2;
b3_reg <= b3;
b4_reg <= b4;
b5_reg <= b5;
b6_reg <= b6;
s12 <= p12;
s1234 <= subnadd_chain34 ? (s12 - p34) : (s12 + p34);
s <= subnadd_chain56 ? (s1234 - p56) : (s1234 + p56);
end
end
endmodule
