15 years agoDVI input and DVI output
I have the problem that I am using Altera cyclone III EPC3C120 Development board.The design example requires an Bitec HSMC Quad Video input daughter card. But I don't have it.Instead I am planning to use the Bitec HSMC DVI input/output daughter card for input and output. Can anyone help me with a sample design with DVI input and DVI output? Sneha3 Replies
Please see if this helps you:
http://www.bitec.ltd.uk/hsmc_dvi_1080p_c120.pdf http://www.bitec.ltd.uk/ciii_video_dev_kit.html BR, - Altera_Forum
I tried to run the code suggested by you but I am getting some errors.It is from the design example from http://www.bitec.ltd.uk/hsmc_dvi.html DVI 1080P Loop-through CIV This sof updates the EDID EEPROM on the HSMC DVI board to correctly report 1080P@60 They are Error: Node instance "auto_inst" instantiates undefined entity "alt_vip_vfb_0_GN" Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 802 warnings Error: Peak virtual memory: 346 megabytes Error: Processing ended: Mon Apr 04 11:12:36 2011 Error: Elapsed time: 00:00:18 Error: Total CPU time (on all processors): 00:00:22 Help please.. Rgds Sneha - Altera_Forum
I also tried to run the design HSMC DVI 1080P SDRAM Loop-through Reference Design But I am facing these errors: Error: Node instance "auto_inst" instantiates undefined entity "my_alt_vip_vfb_top_GN" Error: Node instance "auto_inst" instantiates undefined entity "my_alt_vip_vfb_bot_GN" Can anyone explain what these errors mean?
