15 years agoDual port RAM shared between Nios and async interface
Hi all, I want to upgrade an existing system and I wonder if anyone can give me hints. I have a board with CIII device with Nios and an external Analog Device DSP: both Nios and DSP need to a...
15 years agoIf you used the standard on-chip RAM component in SOPC Builder and created a master to access the second port then you could use a tightly coupled memory connection between the CPU and 2nd memory port (and not have to worry about cache coherency). Creating master logic is pretty easy so you might find this approach to be cleaner and more scalable too.
