15 years agoDSP builder/Vhdl suggestion
Hi.. i have daughtercard tvp5146, its output is 8bit in YCbCr 4:2:2 formate. i want black & white image at VGA output, thats why i have to zero the Cb and Cr part in YCbCr. i want only Y compo...
15 years agothanks Tricky!
i send you the file (ALT_ATLANTIC_SINK) that is having real time video in YCbCr format from the video daughter-card tvp5146, after this file i want only Y component. please help me by code that i can put infront of ALT_ATLANTIC_SINK and having only Y component. this Y component i want to input at VGA port to get Black & white image. ALT_ATLANTIC_SINK is given by : LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE IEEE.numeric_std.ALL; USE STD.textio.ALL; USE work.ALT_CUSP_PACKAGE.ALL; ENTITY ALT_ATLANTIC_SINK IS GENERIC ( NAME : STRING := ""; SIMULATION : INTEGER := SIMULATION_OFF; OPTIMIZED : INTEGER := OPTIMIZED_ON; MANUFACTURER : INTEGER := MANUFACTURER_ALTERA; FAMILY : INTEGER := FAMILY_STRATIX; INIT_FILE : STRING := "UNUSED"; WIDTH : INTEGER := 16; PAGE_SIZE : INTEGER := 1; ADDRESS_WIDTH : INTEGER := 8; -- CEIL(LOG2(PAGE_SIZE)) MEM_WIDTH : INTEGER := 8; -- CEIL(LOG2(PAGES*PAGE_SIZE) END_PACKET_USED: INTEGER := 0; PAGES : INTEGER := 0; -- unused LOG2_PAGES : INTEGER := 0; -- unused WRITE_PORTS : INTEGER := 0; -- unused FULL_AT_START : INTEGER := 0; LATENCY : INTEGER := 1; -- must be 1 READY_LATENCY : INTEGER := 2 ); PORT ( clock : IN STD_LOGIC; reset : IN STD_LOGIC; ----------------- CUSP SIDE SIGNALS ---------------------------------------------------------------------------- ena : IN STD_LOGIC := '1'; addr : IN STD_LOGIC_VECTOR( ADDRESS_WIDTH-1 DOWNTO 0) := (others=>'0'); rdata : OUT STD_LOGIC_VECTOR( WIDTH-1 DOWNTO 0); takeb : IN STD_LOGIC := '0'; -- take a page - block if not there takeb_en : IN STD_LOGIC := '0'; -- takenb : IN STD_LOGIC := '0'; -- take a page - do not worry takenb_en : IN STD_LOGIC := '0'; -- wdata : IN STD_LOGIC_VECTOR( WIDTH-1 DOWNTO 0) := (others=>'0'); -- Unused wdata_en : IN STD_LOGIC := '0'; page_to_take : OUT STD_LOGIC; -- a page is ready to take returnnb : IN STD_LOGIC := '0'; -- give a page returnnb_en : IN STD_LOGIC := '0'; -- eop : OUT STD_LOGIC; stall : OUT STD_LOGIC; ----------------- ATLANTIC SIDE SIGNALS ---------------------------------------------------------------------------- -- atlantic signals ready : OUT STD_LOGIC; valid : IN STD_LOGIC := '1'; data : IN STD_LOGIC_VECTOR(WIDTH-1 DOWNTO 0) := (others=>'0'); startofpacket: IN STD_LOGIC := '0'; endofpacket : IN STD_LOGIC := '0' ); END; ARCHITECTURE rtl OF ALT_ATLANTIC_SINK IS -- It takes 2 cycles for ready to react to valid, so we need buffering for -- that as well as for READY_LATENCY (the time taken for valid to go low -- after ready goes low) CONSTANT DEPTH : INTEGER := READY_LATENCY + 2; SIGNAL skid_full : STD_LOGIC_VECTOR(DEPTH-1 DOWNTO 0); SIGNAL skid_data : STD_LOGIC_VECTOR((WIDTH * DEPTH)-1 DOWNTO 0); SIGNAL skid_eop : STD_LOGIC_VECTOR(DEPTH-1 DOWNTO 0); SIGNAL take : STD_LOGIC; SIGNAL near_empty : STD_LOGIC; SIGNAL empty : STD_LOGIC; SIGNAL avail : STD_LOGIC; SIGNAL skid_full2 : STD_LOGIC_VECTOR(DEPTH+1 DOWNTO 0); SIGNAL skid_load : STD_LOGIC_VECTOR(DEPTH-1 DOWNTO 0); BEGIN -- The FU only ever drives takeb or takenb to get data out take <= ((takeb AND takeb_en) OR (takenb AND takenb_en)) AND ena; near_empty <= NOT skid_full(1); empty <= NOT skid_full(0); avail <= skid_full(0); -- Stall the machine if there isn't any data page_to_take <= avail; stall <= (takeb AND takeb_en) AND NOT avail; -- Latch the output data when requested. The cusp internals expect that -- data will be maintained until it is replaced. PROCESS(clock, reset) BEGIN IF reset = '1' THEN rdata <= (others=>'0'); ELSIF clock'EVENT AND clock = '1' THEN IF (avail AND take) = '1' THEN rdata <= skid_data(WIDTH-1 DOWNTO 0); END IF; END IF; END PROCESS; -- Work out whether we're ready or not... -- We're ready if there will be two spaces available on the next clock PROCESS(clock, reset) BEGIN IF reset = '1' THEN ready <= '0'; ELSIF clock'EVENT AND clock = '1' THEN ready <= (take AND near_empty) OR empty; END IF; END PROCESS; check_depth : IF DEPTH < 2 GENERATE ASSERT FALSE REPORT "DEPTH must be at least 2" SEVERITY ERROR; END GENERATE; skid_full2 <= ( '0' & skid_full & '1' ); -- Copy the input data when it is presented gen_skid : FOR I IN 0 TO DEPTH-1 GENERATE skid_load(I) <= ( ((NOT take) AND (NOT skid_full(I)) AND skid_full2(I)) OR (take AND skid_full(I) AND (NOT skid_full2(I+2))) ); PROCESS(clock, reset) BEGIN IF reset = '1' THEN skid_full(I) <= '0'; skid_data(((I+1)*WIDTH-1) DOWNTO (I*WIDTH)) <= (others => '0'); ELSIF clock'EVENT AND clock = '1' THEN IF (valid AND skid_load(I)) = '1' THEN -- Load this entry of the FIFO skid_full(I) <= '1'; skid_data(((I+1)*WIDTH-1) DOWNTO (I*WIDTH)) <= data; ELSIF take = '1' AND I < DEPTH-1 THEN -- If user has taken data then shift the FIFO skid_full(I) <= skid_full(I+1); skid_data((I+1)*WIDTH-1 DOWNTO I*WIDTH) <= skid_data((I+2)*WIDTH-1 DOWNTO (I+1)*WIDTH); ELSIF take = '1' AND I = DEPTH-1 THEN -- If user has taken data then shift the FIFO skid_full(I) <= '0'; END IF; END IF; END PROCESS; END GENERATE; no_eop_generate: IF END_PACKET_USED = 0 GENERATE eop <= '0'; END GENERATE; eop_generate: IF END_PACKET_USED = 1 GENERATE gen_eopskid : FOR I IN 0 TO DEPTH-1 GENERATE PROCESS(clock, reset) BEGIN IF reset = '1' THEN skid_eop(I) <= '0'; ELSIF clock'EVENT AND clock = '1' THEN IF (valid AND skid_load(I)) = '1' THEN skid_eop(I) <= endofpacket; ELSIF take = '1' AND I < DEPTH-1 THEN skid_eop(I) <= skid_data(I+1); END IF; END IF; END PROCESS; END GENERATE; PROCESS(clock, reset) BEGIN IF reset = '1' THEN eop <= '0'; ELSIF clock'EVENT AND clock = '1' THEN IF (avail AND take) = '1' THEN eop <= skid_eop(0); END IF; END IF; END PROCESS; END GENERATE; END ; Thank You Rizwan
