17 years ago
DSP Builder to ModelSim
Hi , im just perform RTL simulations with the ModelSim software. I add a TestBench block to my DSP builder model. Then I get the following error:
# ** Error: (vsim-3817) Formal port "clk" declared in the entity is not in the component.
# Time: 0 ps Iteration: 0 Region: /tb_dpt2/dut File: ../DSPBuilder_dpt2_import/dpt2.vho
# ** Error: (vsim-3817) Formal port "reset" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in1" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in2" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in3" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in4" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in5" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in6" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in7" declared in the entity is not in the component.
# ** Error: (vsim-3817) Formal port "data_in8" declared in the entity is not in the component.
# ** Error: (vsim-3732) ./hdl/tb_dpt2.vhd(287): No default binding for component at 'dut'.
# (Port 'input3' is not on the entity.)
# Region: /tb_dpt2/dut
# (Port 'output4' is not on the entity.)
# (Port 'input7' is not on the entity.)
# (Port 'aclr' is not on the entity.)
# (Port 'input8' is not on the entity.)
# (Port 'clock' is not on the entity.)
# (Port 'input4' is not on the entity.)
# (Port 'output5' is not on the entity.)
# (Port 'output1' is not on the entity.)
# (Port 'output6' is not on the entity.)
# (Port 'input5' is not on the entity.)
# (Port 'input' is not on the entity.)
# (Port 'output' is not on the entity.)
# (Port 'dpt2_subsystem_output8' is not on the entity.)
# (Port 'input2' is not on the entity.)
# (Port 'output2' is not on the entity.)
# (Port 'input6' is not on the entity.)
# (Port 'output7' is not on the entity.)
# (Port 'input1' is not on the entity.)
# (Port 'output3' is not on the entity.)
# ** Fatal: Bad library format, library not compiled with ALTERA compiler.
# Time: 0 ps Iteration: 0 Instance: /tb_dpt2/clock File: UNKNOWN Line: 293
# FATAL ERROR while loading design
# Error loading design
# Unrecognized dataset prefix: sim
can someone help me with this? thanks !!!
    Nothing interesting in there it seems. Not much else I can do without the design itself.
    Btw, have you tried compiling your DSP Builder design in Signal Compiler yet? Judging from the error statement, there is a chance that your IP cache folder got corrupted (it happens from time to time, especially when you migrate from one version of DSP Builder to another)...
    I would suggest the following:
    1. Delete the existing IP cache folder(s) in your computer... Go to C:\Documents and Settings\<User Name>\
    --> Inside that folder, you should see a .altera.quartus folder
    2. Delete that folder and restart your DSP Builder... see if you still see the same error...
    Best of luck.
