15 years agoDSP Builder Simulink Errors
i have quartus ii 9.0 web edition and matlab r2008a. recently i installed dsp builder v9.0 successfully. but when i try to add dsp blocks i get errors like this: -------------------------------...
15 years ago --- Quote Start --- I've just switched my computer to Turkish using Control Panel and have replicated your problem. The good news is there's a workaround: switch your computer to not turkish. The bad news is that's all I can suggest. You'll have to wait for the tool to be released with a fix for this. This appears to be the cause of the problem: (...://java.sys-con.com/node/46241) --- Quote End --- Switching language is very disturbing because of Turkish keyboard but yes it is absolutely the reason of this bug and there is no solution yet. So nothing much to do. Thank you very much for your help. isumairu
