15 years agoDSP Builder Simulink Errors
i have quartus ii 9.0 web edition and matlab r2008a. recently i installed dsp builder v9.0 successfully. but when i try to add dsp blocks i get errors like this: -------------------------------...
15 years agoI've just switched my computer to Turkish using Control Panel and have replicated your problem. The good news is there's a workaround: switch your computer to not turkish. The bad news is that's all I can suggest. You'll have to wait for the tool to be released with a fix for this.
This appears to be the cause of the problem: http://java.sys-con.com/node/46241 (http://java.sys-con.com/node/46241)
