13 years agodsp builder-quartus project
hello, i have created a project for multichannel duc, and able to generate quartus project file. the top module is entity duc is port ( channel : in std_logic_vector(7 d...
13 years ago --- Quote Start --- If you want a processor to update your coefficients then this bus is generated(data, address, write...). If you don't want update then set your filter block to constant coeffs and the bus will disappear. By the way channel input is not needed ! as it is not connected internally as far as I know. --- Quote End --- hello, i changed the read/write mode into constant, for all the filters and NCO. but still it is showing the same in NCO entity... component working_duc_nco is
port (
busin_d : in std_logic_vector(31 downto 0);
busin_a : in std_logic_vector(15 downto 0);
busin_w : in std_logic_vector(0 downto 0);
xin_c : in std_logic_vector(7 downto 0);
xin_v : in std_logic_vector(0 downto 0);
xin_p_0 : in std_logic_vector(23 downto 0);
xin_p_1 : in std_logic_vector(23 downto 0);
xin_p_2 : in std_logic_vector(23 downto 0);
xin_s_0 : in std_logic_vector(0 downto 0);
xin_s_1 : in std_logic_vector(0 downto 0);
xin_s_2 : in std_logic_vector(0 downto 0);
sinout_0 : out std_logic_vector(17 downto 0);
sinout_1 : out std_logic_vector(17 downto 0);
sinout_2 : out std_logic_vector(17 downto 0);
cosout_0 : out std_logic_vector(17 downto 0);
cosout_1 : out std_logic_vector(17 downto 0);
cosout_2 : out std_logic_vector(17 downto 0);
ncoout_v : out std_logic_vector(0 downto 0);
ncoout_c : out std_logic_vector(7 downto 0);
clk : in std_logic;
areset : in std_logic;
h_areset : in std_logic
end component;
what change should i have to make ?
