18 years agodsp builder-Prewitt edge detector
Hello, I have to present what exactly do all of implementation of Prewitt edge detection design in Dsp-Builder. I find informations in "Edge Detection Using SOPC Builder and DSP Builder Tool Fl...
17 years agowell I had got some replies from mysupport (Altera) where initially they asked me to go through one application note based on real time edge detection and so I tried working it out the same way as mentioned. But when I get to the part where I have to add the NIOS component, I am not able to even get it working using the SOPC builder. I am totally new into this field of softcore processors and so struggling at this stage.
I did get the component in HDL format from Simulink but have no clues how it is gonna work. What do u advise.. is it better to write the algorithm directly in HDL or get it from Simulink. Ur experience on this project should help me some insight on some of the problems that you also might have faced when u were working with this project. Do pass on ur comments, it will be of great value for me. Regards, Abin
