18 years agodsp builder-Prewitt edge detector
Hello, I have to present what exactly do all of implementation of Prewitt edge detection design in Dsp-Builder. I find informations in "Edge Detection Using SOPC Builder and DSP Builder Tool Fl...
17 years agoI converted the codes from Simulink to HDL. The codes which are generated seems to be quite different. I have a file .mdl and .mdlxml generated along with the other built in function using by DSP builder. I did also see an interface, entity and architecture description file.
My query is, is it possible to add additional components directly to the code here and compile it. Well I did add some output ports onto the same code and tried building it, but I dont see them under the pins. I am not sure why.
