15 years agoDsp builder port number mismatches
Hello Guys, I am using simulink on Centos system at the university and recently started using Altera DSP builder blocksets . I am facing a problem, whenever i try adding ports to the block through...
15 years agoIn which case you should type the following commands:
addpath /sw/altera/quartus/9.0/quartus/dsp_builder/bin addpath /sw/altera/quartus/9.0/quartus/dsp_builder/bin/matlab addpath /sw/altera/quartus/9.0/quartus/dsp_builder/bin/mdllibrary To make sure these get executed every time, add them to a startup.m file as described in http://www.mathworks.com/help/techdoc/matlab_env/f8-4994.html (http://www.mathworks.com/help/techdoc/matlab_env/f8-4994.html).
