14 years agoDSP Builder not recognizing Fixed Point Toolbox License
Hi I recently installed DSP Builder and upon simulating an Design using the advanced Blockset, I realized that my Matlab license is missing the Fixed-Point Toolbox. However, after installing sa...
12 years agoHello everyone i'm working with the design example model called: 1-Carrier, 2-Antenna WCDMA Digital Up Converter & I receive similar error with the Fixed Point License, that is the error:
License checkout failed. License Manager Error -18 Make sure the license file on the MATLAB client matches the license file of the license server and that the license server has been started properly. Troubleshoot this issue by visiting: http://www.mathworks.com/support/lme/r2010b/18 Diagnostic Information: Feature: fixed_point_toolbox License path: C:\License\License_dsp.dat;C:\Users\Alien\AppData\Roaming\MathWorks\MATLAB\R2010b_licenses;C:\Program Files\MATLAB\R2010b\licenses\license.dat;C:\Program Files\MATLAB\R2010b\licenses\network.lic FLEXnet Licensing error: -18,147. I tried changing some properties in the Fixed Point Tool like recommend matlab summary: Which consists in edit some parameters like "force off" in Fixed-Point instrumentation mode and changing to "double" in data type override and apply to "all numeric types" but i obtain the same result. Someone have run this model? ¡I appreciate your help to fix that! Note: I attached a image capture of this error Alex.
